    How to style your 3d model in Rayon
    Styling a 3D model in Rayon: applying colours, images and textures to walls and blocks, saving 3D styles and creating glass, plus how styles carry into level views and sections.
    Learn how to style walls, openings and blocks in Rayon's 3D canvas, save and reuse 3D styles, and link them to 2D level views, sections, cut fills, level markers and section lines.
    1. Setting wall thickness and 2D or 3D styling
      Select a wall in the 3D model and set its thickness in the style panel, for example 0.3 m, 300 mm or 30 cm depending on the model's units. A toggle beneath switches between 2D and 3D styling properties, and the 3D properties are used first.
    2. Solid colour fills and opacity
      A solid fill lets you pick a face colour from swatches and colour palettes. Changing the opacity affects the whole wall rather than the intensity of the colour, which is useful for glass effects.
    3. Applying an image to a surface
      Select an image from the desktop or another canvas, such as a mood board, or pick a style from the Rayon library. Setting the tint to white shows the pure material, and a transparency toggle lets you see through the wall while modelling.
    4. Tiling textures with scale and rotation
      An image applied alone is stretched across the wall, so use the texture fill to tile it. Adjust the scale to make the texture detail finer, the rotation for something like timber panelling, the offset for position, and add a tint, such as cream instead of white.
    5. Saving and applying 3D styles
      Click the plus button to name and save the settings as a 3D style, for example a light grey 30 cm wall, which goes into the style library. Apply it to other walls with the pick style option or from the styles quadrant button for consistent styling.
    6. Creating a glass effect
      Select the curved partition, edit its style, change the face to a blue or turquoise colour and lower the opacity to about 20 percent. Save the result as a style to apply across other pieces of glass.
    7. Styling blocks: edit versus override
      Selecting a block offers override or edit. Editing the chair's parts with a wood image texture, scale adjustments and a dark grey cushion changes every instance of the block in the model, while override changes only the selected instance.
    8. Saving and reusing block styles
      Save the edited look as a style, such as a timber finish, which appears with a cube icon for solids. Applying it to a table inside another block gave the right scale and wood effect without further edits.
    9. From 3D to 2D: level views
      A level view slices through the building at about 1.2 m and stays linked to the 3D model, with components using the same style. Toggle to the 2D styling properties to set the plan fill and stroke.
    10. Setting 2D fills, strokes and face fills
      In 2D you can switch to a black fill or change the stroke. The face fill is the look shown in sections and elevations, and editing a style's face fill or face stroke in a section updates every component using that style.
    11. Setting cut fills for sections
      The cut fill controls the cut marks where a section slices through walls, windows or blocks, and can be a solid, a colour such as red for a demolition drawing, or a texture. Reducing the oblique compact scale, for example to 0.2, strengthens the diagonal cut.
    12. Styling levels and section lines
      Level markers have text size, font and style, stroke, extensions, endpoints and endpoint size, with the head switchable from text to a block and an optional background or border. Save it as a style to keep level markers consistent, and section lines work the same way.
