    How to Turn a Site Survey Sketch into a Floor Plan with AI
    21:00
    Turning a survey sketch into a floor plan in Rayon: importing, scaling and AI plan generation, plus plan corrections, layout changes, presentation sheets and annotations.
    Learn how to convert a hand-drawn site survey sketch into an editable, scaled floor plan in Rayon using AI, develop design iterations, and prepare presentation sheets to share with clients.
    1. Import and Scale the Survey PDF
      Create a new model and navigate to the left-hand toolbar to select import and PDF. Locate the scanned site survey document and enter a known check dimension, such as 6,000 mm, to establish accurate real-world scaling. Click continue to bring the scaled PDF sketch directly into the workspace canvas.
    2. Generate Floor Plan Using AI
      Open the toolbar located below and select the generate plan feature from the AI tools menu. Select the imported survey drawing on the canvas and click the submit button to begin processing the sketch. The AI generates an editable floor plan containing Rayon wall blocks, doors, windows, and tagged room zones with calculated floor areas.
    3. Align Walls and Apply Styles
      Inspect the generated walls and manually adjust partition lines so the geometry snaps into a squarer, orthogonal arrangement. Straighten hand-drawn discrepancies across internal partitions and exterior boundaries to clean up the imported survey geometry. Apply visual styling to differentiate elements by setting the external walls to a solid black color fill.
    4. Diagram Spatial Issues and Concept Moves
      Copy the existing plan across the canvas to visually diagram the core architectural challenges identified during the site survey. Draw colored shapes with transparency fills and removed strokes to highlight issues with the entrance lobby, living room connections, and kitchen layout. Duplicate the drawing once more to illustrate proposed conceptual solutions using matching colored zones for client clarity.
    5. Remodel Layout and Add Library Blocks
      Copy and ungroup the plan to begin modeling the proposed architectural layout, stretching or deleting existing wall blocks as needed. Open the blocks library to search for and place residential items, including entry wardrobes, benches, fitted kitchen units, and dining furniture. Enhance the interior spaces by drawing custom joinery rectangles, positioning glazed glass screens, and applying textures such as herringbone wood flooring.
    6. Set Up Presentation Sheets in Paper Canvas
      Navigate to the paper canvas, create a new A3 landscape page, and bring in views from the model canvas. Scale the drawings accurately at 1 to 50, duplicate the viewports across multiple pages, and insert a scale bar block from the library. Add descriptive page titles, subheadings, and text annotations to clearly explain the existing issues and proposed spatial solutions.
    7. Publish and Share the Presentation
      Navigate to the share menu in the top right corner and select the share a presentation option. Review all assembled sheets in the pages panel, click publish, and generate an active presentation web link. Copy the generated link to distribute to clients via email or review the completed multi-page slide presentation directly within the browser.
    How to Import DWG, PDF & Image Files
    Bring DWG, PDF and image files into Rayon and start drawing on top of them.
    5:00
    How to Use, Create and Manage Blocks in Rayon
    From creating blocks to publishing a shared library.
    19:00
    How I’d Fix This Georgian Country Home Layout: Architect Reviews
    From an existing Georgian home layout to a revised plan.
    24:00
    Become a trainer
    You use Rayon, and want to teach others?
    Become a trainer for our academy, and get paid to share your passion!
    © 2026 Rayon. All rights reserved.
