    How to draw & present multiple floor plan options to a client (tutorial)
    How a barn conversion on England's south-west coast evolved through several floor plan options to the final design proposal.
    Learn how to develop and present multiple floor plan design options for a client project in Rayon. The workflow covers duplicating plans on the canvas, arranging blocks and finishes, setting up paper canvas sheets with viewports, and exporting drawings to PDF.
    1. Duplicate Floor Plans on the Canvas
      Select and copy the base floor plan across the canvas so that multiple design options sit side by side. Stripping back the duplicate layouts allows you to easily cross-reference dimensions while testing alternative spatial arrangements. This canvas-based approach provides a clear overview without having to toggle separate layers on and off.
    2. Insert Furniture Blocks From Block Library
      Browse or search the block library on the left panel to locate required furniture, such as an L-shaped sofa or complete kitchen assemblies. Place blocks onto the plan and select top-down, front, or side view options in the right-hand panel to fit your drawing orientation. Rotate or modify individual elements within group blocks to suit the room dimensions.
    3. Assign Room Zones and Floor Finishes
      Copy existing room zones into the modified options to automatically recognize enclosed spaces. Apply desired surface materials, such as timber flooring, across the defined areas through the zone settings. Place scale figures from the library or earlier drawings into the layout to demonstrate how each space functions.
    4. Standardize Graphic Styles Across Blocks
      Select newly placed components, such as TV units or cabinetry, to inspect their applied graphic styles in the right panel. Click the four dots icon to browse styles and assign the standard furniture fill style across all elements. Aligning border and fill styling ensures the drawing appears visually consistent without overpowering the architectural lines.
    5. Model Partitions and Trim Wall Intersections
      Draw low-level partition walls to establish clear visual divides between adjacent functional zones like the kitchen and dining areas. Adjust wall layouts in tight spaces such as the bathroom, aligning geometry to accommodate wardrobes and fixtures. Type TR to trim intersecting wall edges cleanly, and match wall thickness and color to existing structural lines.
    6. Create Sheets in the Paper Canvas
      Switch from the model canvas to the paper canvas to prepare drawings for client presentation. Click the plus button to generate a new page and select an appropriate sheet format such as A2. Alternatively, copy across existing layout sheets to preserve title block layouts and drawing borders.
    7. Add Viewports and Set Drawing Scales
      Add a view onto the paper canvas to create an active viewport peering directly into the model canvas geometry. Pan inside the viewport to frame the corresponding layout option alongside its sheet border. Set the viewport scale on the right-hand properties panel, adjusting to 1:100, and crop the view boundary cleanly.
    8. Update Title Block Properties and Revisions
      Select the copied title block on each sheet and edit its properties in the right panel to update drawing numbers for each option. Click directly into the title block fields to append new revision markers and the current date. Custom or preset title blocks can also be pulled directly from the block library as needed.
    9. Export Presentation Sheets as PDF
      Open the pages panel on the left side of the screen to prepare the sheets for client delivery. Select the export option, define the page range to include specific sheets or all options, and choose the desired image quality. Download the resulting PDF file to package and distribute the visual proposals.
    How I Populate a Floor Plan to Show How a Space Actually Works
    How I populate a floor plan to show how a space actually works
    A floor plan with nothing in it tells a client where the walls are.
    Architects Can Do Interior Design. Here's What It Took Me to Learn
    Architects can do interior design. here's what it took me to learn
    The line between architecture and interior design is blurrier in practice than it appears from the outside.
    How I Go From an Architect's Drawing to a Furnished Interior Floor Plan
    How I go from an architect's drawing to a furnished interior floor plan
    Going from an architect's drawing to a fully furnished interior floor plan is one of the most common handover moments in interior design practice.
