How I use AI to plan lighting for my interior design projects
Creating a lighting plan with Rayon’s AI agent: placing fittings room by room, refining layouts, adding switches and circuits, and building a linked lighting schedule with reference images.
Learn how to develop a full apartment lighting plan in Rayon by utilizing the AI agent to place fixtures, draw circuits, and generate an automated lighting schedule. The tutorial demonstrates how to import library symbols, prompt the agent for room-by-room layouts, manually refine alignments, and produce client-ready documentation.
Create a White Overlay Layer
Create a new layer named white overlay and place a solid white shape over the entire apartment floor plan. Remove the shape's stroke, lock the shape, and lower the opacity of the overlay layer. This knocks back the background drawing so that newly placed lighting symbols stand out clearly without visual competition.
Import Lighting Symbols via AI Chat
Open the AI chat panel and prompt the AI agent to locate the UK lighting symbol schedule in Rayon's block library. Request standard blocks including spotlights, wall lights, pendants, linear LEDs, and ceiling-mounted luminaires to import them onto the page. The agent loads the lighting symbols and associated text notes to establish the graphic rules for the plan.
Prompt AI to Populate Bedroom Lighting
Ask the AI agent to populate the bedrooms with cozy ambient ceiling lights, bedside wall reading lights, and linear wardrobe LEDs. Enter a follow-up prompt to swap the lights above the bed to pendant fittings and add ceiling luminaires beside the bed. Have the agent place a wall light over the dressing table while generating element tags and notes.
Generate Living, Bathroom, and Hallway Layouts
Prompt the AI agent to insert a grid of four ceiling luminaires in the living area along with reading wall lights next to the sofa. Direct the agent to add bathroom ceiling luminaires and sink wall lights, followed by centered hallway spotlights and an artwork wall light. The agent distributes the requested fittings across the floor plan while accounting for fixed constraints like kitchen extracts.
Refine Fixture Positions and Alignment Lines
Manually rotate inverted wall light symbols and remove extra spotlights in the hallway to focus on the feature wall. Adjust bathroom fittings to align with plumbing fixtures, center bedroom lights on the bed, and create a dashed red line style named alignment. Use these alignment guides to snap fixtures to architectural openings and permanent structural elements.
Add Wall Switches and Circuit Lines
Instruct the AI agent to place wall switches and curved circuit lines connecting fixtures across each room. Prompt the agent to locate bathroom switches on the exterior wall, add dimmer switches, and position an independent wall light switch behind the sofa. The agent inserts switch symbols, draws colored circuit lines, and attaches itemized control notes.
Configure Motion Sensors for Wardrobe Lights
Direct the AI agent to remove manual wall switches for linear LEDs in wardrobes, cupboards, and utility spaces. Prompt the agent to assign these storage lights to automatic PIR motion sensors instead. The agent updates the layout by removing standard switch symbols and attaching PIR motion sensor indicators to each linear LED run.
Generate an Automated Lighting Schedule Table
Prompt the AI agent to compile a comprehensive lighting schedule alongside the floor plan that lists element tags, fitting types, locations, and notes. Ask the agent to include visual reference images illustrating each primary light fixture category. The agent builds an alternating-tone smart table linked directly to the model's block instances that updates with layout revisions.
A low-energy home hidden in the oxfordshire countryside | charlie luxton design
From a home tucked into the landscape to the stories within.
How I built a mediterranean interior project portfolio (Rayon template)
From a Mediterranean template to a project portfolio.
