    How to draw atmospheric lighting plans for client coordination
    28:00
    Build a lighting plan: define the strategy, place fixtures from the block library, locate switches, dimension the layout, add a legend and present it.
    This tutorial demonstrates how to develop a comprehensive atmospheric lighting layout from a finalized architectural floor plan in Rayon. Viewers learn to zone room atmospheres, place and dimension lighting fixtures, configure switching circuits, assemble a schedule legend, and publish presentation sheets for client coordination.
    1. Set Up White Knockout Background Layer
      Create a new layer named white and draw a rectangle over the isolated floor plan drawing. Set the rectangle fill to a solid fill and reduce the opacity to 50 percent to knock back the background drawing. Lock the layer to prevent accidental edits to the existing floor plan geometry while adding lighting layouts.
    2. Diagram Spatial Lighting Zones Using Circles
      Create two separate layers named lighting zones and lighting, arranging the zones layer behind the fixtures. Draw colored circles across the plan to define specific lighting requirements, using distinct tones for working task areas like kitchens and subtle feature zones like living areas. Use these visual zones as a conceptual guide to determine fixture moods before placing symbols.
    3. Place Fixture Symbols and Draw Track Lighting
      Open the block library, browse lighting symbols, and drag standard UK fixtures such as spotlights, wall sconces, and pendants onto the canvas. Scale and position downlights centrally over functional surfaces like kitchen counters, dining areas, and bathroom mirrors. In hallways, draw a linear track line with dashed styling, save the style, and position directional spotlights along it.
    4. Add Switches and Draw Circuit Lines
      Insert standard on-off and multi-gang switch blocks from the block library and align them along entry walls and hallway transitions. Assign switch points to control lighting scenes, separate wall lights, and exterior or motion-activated bathroom fixtures. Connect switches to their corresponding light fixtures by drawing weighted connection lines, saving the graphic settings as a reusable line style.
    5. Dimension Fixture Alignments and Equal Spacings
      Access the dimension tab and draw dashed reference centerlines measured off solid partition walls. Place millimeter dimensions from fixed walls to lighting centers, adjusting line weights and dimension tails for clarity. Replace fixed numerical measurements with EQ text annotations where fixtures should float equally between walls to accommodate site tolerances.
    6. Construct a Schedule Legend with Codes
      Copy instances of every placed lighting fixture symbol to an open area of the canvas and construct a schedule table using rectangles. Insert text labels alongside each symbol to describe fixtures such as recessed downlights, track lights, and external fittings. Add coding tags like A and B to differentiate specialized fixtures, such as IP-rated bathroom lights and distinct wall sconces.
    7. Compose Layout Sheet Viewports and Title Block
      Switch to the paper canvas and add a new landscape A3 page using the layers panel. Add a model view scaled to 1:50 cropped around the floor plan, then place an adjacent viewport displaying the schedule legend. Insert a standard title block from the title blocks and annotations library, snapping it into position on the sheet.
    8. Publish and Update Interactive Presentation Link
      Open the share menu, select presentation, and enable the presentation toggle to generate a viewable client link. Open the link in a browser to inspect the published multi-page set with the dimmed architectural background. When fixture modifications are made on the canvas, return to the presentation panel and click the update button to republish the shared link.
    Exporting & template set up
    Discover how to transition files and customize templates when moving from traditional drafting tools. This guide covers the initial setup steps for a smooth workflow shift.
