    9 Tools every interior designer needs in your workflow
    18:00
    Nine Rayon tools for the full interior design workflow, from mood boards, blocks and FF&E data to styles, pages, views and live presentations.
    This guide demonstrates how to build an interior design project in Rayon by connecting mood boards, floor plans, block data schedules, and presentations within one file. Users learn to draft architectural elements, manage graphic styles, and publish live client presentation decks.
    1. Importing Images onto the Paper Canvas
      Open the paper canvas from the left panel to arrange mood boards and visual references. Drag and drop image files directly from your desktop, paste them from web browsers, or use the top-left import button. Scale pictures to fit your composition and double-click any image to crop its boundaries.
    2. Removing Backgrounds with AI Tools
      Select an imported product image and access the AI tools on the bottom toolbar or the right-hand style panel. Click remove background to automatically isolate the main subject and eliminate busy surroundings in seconds. Arrange these clean product cutouts over other visuals to compose uncluttered mood boards.
    3. Drafting Walls, Openings, and Zones
      Switch to the model canvas, select the wall tool from the bottom panel, and set thickness in the style panel before drawing. Place openings from the library to host doors or windows automatically within walls. Close geometry, clean intersections with the trim tool, and insert zones to generate automatic square-meter area tags.
    4. Adding Furniture from the Block Library
      Open the block library to search scaled items across furniture, fixtures, lighting, and layout collections. Drag blocks into the model canvas and switch between plan, front, and side views using active block settings. Select parametric blocks to stretch dimensions without breaking geometry, or click edit to modify individual components.
    5. Attaching Product Properties to Blocks
      Select any placed block and view its custom properties in the right inspector panel. Use the plus button to add custom data fields such as product name, price point, currency, and supplier links. This attached information stays with the block and syncs automatically into structured tables and schedules.
    6. Managing Graphic Styles in the Inspector
      Select an element to adjust line thickness, stroke settings, and fill hatches within the right-hand style panel. Save the appearance as a named style to establish a consistent visual hierarchy across your plan. Apply saved styles using pick style, ensuring future edits update automatically across all assigned elements.
    7. Setting Up Pages and Drawing Views
      Return to the paper canvas and click the plus icon to add presentation pages in formats like A3 or A4. Add views to insert live viewports linked directly to your model canvas drawings. Adjust viewport scale on the right panel and crop edges to position drawings beside presentation imagery.
    8. Applying Automatic Page Numbering Tags
      Set page ordering by row or column in the left page panel to establish your presentation sequence. Activate the page numbering tool and click each sheet to place an automatic page number tag in the corner. Customize tag styles in the right inspector, knowing numbers update automatically when pages are reordered.
    9. Sharing Interactive Presentations via Live Links
      Click share in the top-right corner and switch on the presentation mode toggle. Copy or open the live link to let clients interactively review slides and zoom into drawings. When you update drawings or sheets, click the reload button under share so client views refresh to the latest version.
    How to Build a Client Ready Presentation (Step-by-step in Rayon)
    How to build a client ready presentation (step-by-step in Rayon)
    Turn a finished drawing set into a client-ready presentation, without leaving Rayon.
    From Client Brief to Concept Sign-Off: My Rayon Process
    From client brief to concept sign-off: my Rayon process
    Every design project starts with a concept.
    Why Your Interior Design Project Presentation Doesn't Look Professional (and How to Fix It)
    Why your interior design project presentation doesn't look professional (and how to fix it)
    The gap between an interior design portfolio that looks amateur and one that looks like it came from a professional studio is almost never about the quality of the work inside it.
