Can AI actually speed up your interior design process? I tested it live
Testing Rayon’s AI agent on an old DWG: converting loose line work into a floor plan, creating a zoning plan and area schedule, generating a lighting plan, then annotating and dimensioning.
Learn how to use Rayon's AI agent to transform an imported CAD DWG line-work file into native BIM elements, followed by generating a colored zoning plan, a routed lighting plan, and automated room dimensions.
Import DWG Floor Plan File
Import an older CAD floor plan into Rayon using a DWG file format. The imported plan appears on the interface as loose lines rather than BIM components. This imported line work serves as the starting geometry for the subsequent AI conversion workflow.
Prompt AI Agent to Structure Plan
Paste a comprehensive cleanup prompt into the AI agent text box to convert the loose line work into native Rayon elements. Direct the AI agent to remove page borders, title blocks, and annotations while organizing remaining shapes into named layers by entity type. Specify tracing walls and openings with native tools, creating separate blocks for furniture and fixtures, and placing room zones on a dedicated layer.
Review Converted Elements and Layers
Inspect the canvas once the AI agent finishes generating the floor plan from the prompt. Clicking on individual elements confirms that loose lines have been converted into distinct wall, window, and door components categorized on dedicated layers. This organizes the model into a native BIM workflow without requiring manual redrawing.
Request AI Generated Zoning Plan
Ask the AI agent to create a zoning plan directly from the newly structured base floor plan. Input a prompt instructing the tool to fill each room with a light distinct color, maintain legible labels above fills, and place zone shapes onto a zones layer. Request an added compact color legend and an inserted canvas table listing every room name alongside its surface area.
Inspect Zoning Plan and Room Table
Examine the generated zoning layout to verify that each designated room contains a distinct color fill. Confirm that the AI agent successfully generated the zones layer and inserted the requested data table directly on the canvas. Reviewing the automated output illustrates what a complete interior design zoning plan entails without manual drafting.
Prompt AI Agent for Lighting Plan
Submit a detailed prompt instructing the AI agent to build a lighting plan based on the existing floor plan. Instruct the AI to position ceiling spotlights according to room functions and furniture layouts, route neat wiring between fixtures, and place a switch near each entrance. Request that all spotlights, wiring, and switches be organized on a lighting layer, supplemented by a symbol legend and a quantity table.
Review Generated Lighting Layout and Table
Examine the generated lighting plan on the canvas to see the placed spotlights and their connected wiring networks. Verify that the AI agent added switches and inserted a technical table showing total spotlight counts and total linear wiring length. This automated layout provides an immediate technical baseline that can be refined for project-specific needs.
Prompt AI for Annotations and Dimensions
Enter a final prompt requesting clear dimensions and annotations across the floor plan. Instruct the AI agent to show overall building lengths, opening widths, distances between openings, and room dimensions while labeling room names and floor areas. Specify avoiding overlaps with existing geometry and removing any duplicate measurements before hitting enter to generate the results.
How I built a luxury interior design project presentation (Rayon template)
A luxury project deserves a presentation that matches it.
How I’d fix this georgian country home layout: architect reviews
From an existing Georgian home layout to a revised plan.
