AI can build 3d furniture now. here's how (interior design & architecture)
Turning product photos into 3D furniture with Rayon’s AI: editing and placing blocks, rendering the scene, refining with annotations and reference images, and adding renders to a presentation.
Learn how to generate editable 3D furniture blocks from reference photos using Rayon AI and compose them within an architectural floor plan layout. The tutorial demonstrates how to customize block geometry, position models, configure saved camera views, guide AI rendering with annotations, and place the final 4K render onto a presentation canvas.
Clear Opportunity Space in the Model
Navigate to the bottom right opportunity zone of the co-working space layout to prepare the reception area. Select and delete the existing 3D blocks in this section to create room for new furniture modeling. This clears open space while maintaining the link between the 2D floor plan level and the 3D model.
Generate Editable 3D Block From Image
Head into the 3D environment and open the AI tools menu located at the bottom. Choose the editable shapes option rather than static mesh so the resulting geometry can be modified and refined. Select a product image reference from the model canvas and send the request to generate a 3D furniture block.
Edit Geometry and Position the Sofa
Double-click into the generated 3D block to access its fully editable components and identified cushions. Modify cushion radius and scaling to make individual elements rounder or blockier according to design preferences. Use the move command to seat the sofa flush on the floor, then mirror it across the room and snap it into alignment.
Generate and Align Matching Furniture
Generate an armchair and a coffee table from their respective reference images using the AI generation tool. Use the move tool to select a corner of the generated armchair and position it level with the sofa corner. Use the rotate tool to orient the armchair into place, and align the coffee table properly to the floor slab.
Configure and Save Camera View
Pan through the 3D environment to frame an appealing viewing angle of the newly arranged furniture space. Click the camera icon on the left-hand side and select the plus button to generate a new view into the scene. Adjust the zoom, orientation, and rotation settings until satisfied, then click done to store the camera viewpoint.
Render Scene and Inspect Output Geometry
Click the render button to open the prompt box and generate an initial visual of the office reception area. Review the produced lighting, atmosphere, and material finishes within the resulting preview render. Use the compare tool slider to confirm that the generated rendering precisely adheres to the original input model geometry.
Refine Render With Annotations and References
Select the annotate tool and use the marker to highlight specific areas such as the back wall, rug zone, and artwork placement. Supply additional text prompts to request cream wall tones, matching sofa colors, and people sitting on furniture or walking in the distance. Attach reference images for atmosphere and specific products so the AI renderer incorporates the desired warmth and style.
Adjust Quality and Insert Into Canvas
Navigate to the right-hand panel to adjust the AI render quality settings from default to 4K resolution. Re-render the scene to generate a crisper, high-quality visualization matching the prompted style and lighting. Click insert view to embed the completed render directly into the presentation paper canvas, where it stays linked to update alongside camera adjustments.
Interior design AI rendering from floor plan to visualisation in seconds
Most clients can't read a floor plan the way a designer does.
The AI interior design workflow that changed how I work (Rayon AI)
Bridge the gap between a vague client brief and a clear feasibility scheme.
Starting an ADU renovation: from brief to drawing setup
Welcome to the Inside a Residential Renovation: From Brief to Final Drawing Set series.
